Tokico D-Spec on deck
Re: Tokico D-Spec on deck
I thought you had to be active duty to rent the bays at Ft Myers? Are they open on Sundays?
HappyIdiot
They are opened from 9-5 on Sundays. We would need to call/verify. They don't open until 12:30 on Fridays. I just added the link to my last post.
My Name is Adam.
HappyIdiot
I talked with a guy there and he said it is possible for contractors to rent bays. They just need to bring their CACs.
My Name is Adam.
Thanks for calling, it's been crazy here at the office today.
I guess I'll head to Ft Myer at 9:00 on Sunday.
HappyIdiot
Sounds good!
Jason, I can't remember, do you have a CAC? If not, did you want to meet somewhere?
My Name is Adam.
I plan on being at the hobby shop NO LATER than 09:30. I'm setting an alarm and everything.
No, I don't have one. There is a 7-11 not too far from the west gate Whatcha think? 9:15?
HappyIdiot
Sounds good! I'll see you at 9:15.ElZorro wrote:No, I don't have one. There is a 7-11 not too far from the west gate Whatcha think? 9:15?
My Name is Adam.
well, they're on... and the rears are especially noisy. going to have to do some research, I think I may be missing a piece between the spring and the top-hat that came with the kit.
but they're on, thanks to Jason and Adam.
HappyIdiot
My Name is Adam.
the ride is better, if I plug my ears
I don't have a free weekend for a few months. going to call PTuning and have them look at it when I get an alignment.
HappyIdiot
On the other hand, we can upgrade your factory sound so you wont hear them
My Name is Adam.
Mr Kleen wrote:well, they're on... and the rears are especially noisy. going to have to do some research, I think I may be missing a piece between the spring and the top-hat that came with the kit.![]()
damn, that's not cool. what piece do you think you're missing? if there's a washer missing, you could run into problems where the tophat meets the strut shaft.
Congrats on the install! What kind of noise are you getting in the rear? Is it NVH or more of a clunking type noise? How do they feel in the corners?!?!
goob_os101
complacent wrote:Mr Kleen wrote:well, they're on... and the rears are especially noisy. going to have to do some research, I think I may be missing a piece between the spring and the top-hat that came with the kit.![]()
Thats what I am missing and it sound like a chicken is stuffed in my rear driver side strut!
Rubber strip between the rear springs and the tophat.
doh! is that what's missing? ugh!Mr Kleen wrote:Rubber strip between the rear springs and the tophat.
Yeah. If the stocks needed to be modified and reused, it was beyond me. Researching now...
edit: so it appears that all 2004 Imprezas need either spacers or 2003 rear top hats. I was led to believe that only the 2004 waggons needed this.
guess I didn't do a thorough job with my homework on this one.
edit 2: but why did the kit come with rear top hats but no rubber for the spring to seat in? do I need just a portion of a 2003 top hat?
Thats a PITA... they gave you a complete replacement tophat, it should have been right.
HappyIdiot
It wouldn't make sense to include a top hat that didn't work, unless it was a 02-03 top hat, which it wasn't. That was a strange looking top hat too. You could reuse your stock rear 04 tops hats since it has the rubber.Mr Kleen wrote: edit: so it appears that all 2004 Imprezas need either spacers or 2003 rear top hats. I was led to believe that only the 2004 waggons needed this.
Here are the spacers I used for the rear, Scooby 921 Spacers
My Name is Adam.
Wow, I remember this! I was originally going to go with a D-spec set in my 04 wrx.. but i decided against it because of the rear top-hat thing.Mr Kleen wrote:Yeah. If the stocks needed to be modified and reused, it was beyond me. Researching now...
damn. at least the rears are pretty easy to take apart?
The top of the ne spring is a much larger diameter so no part of the stock top hats would work. Not sure how that spacer would remedy this situation. I wish I wasn't in class so I could make phonecalls and do more research.
