Getting tuned Oct. 12th at Agile Automotive
UPDATE:
Well, I am still having trouble reading the CEL code "?????". Dan at MachV said that you can tune around the misfires from larger injectors and the CEL light can still come on...he said I should still be able to tune so that the lights don't come on.
My idle is still rough at 1000RPMs. Also, now when accelerating slowly, it gets jerky. I need to get this all straightened out...not acceptable at this point.
Might just buy the StreetTuner software and either try to reprogram w/ the injectors or put the stock injectors back in and tune for those.
Live and learn.
If your planing on going to a larger turbo in the future (TD06 20G or larger) I would say grab a set of Helix 820cc injectors and tune for those. If you don't think you'll go larger than say a vf22 or TD05 16G than go back to stock. My guess is that if Hill couldn't get them to idle right and accelerate smoothly, then why spend $200 on software plus a huge amount of time and trouble that will likely net you the same results. Helix injectors go for about $460 (though you may find someone selling used for less) and my guess is that would solve your issues.
If you want me to attempt to pull the CEL with my tool before tuesday let me know. We can meet up somewhere.
drwrx wrote:If your planing on going to a larger turbo in the future (TD06 20G or larger) I would say grab a set of Helix 820cc injectors and tune for those. If you don't think you'll go larger than say a vf22 or TD05 16G than go back to stock. My guess is that if Hill couldn't get them to idle right and accelerate smoothly, then why spend $200 on software plus a huge amount of time and trouble that will likely net you the same results. Helix injectors go for about $460 (though you may find someone selling used for less) and my guess is that would solve your issues.
If I get the StreetTuner I can fine tune it myself or have someone more knowledgable help me out. I always wanted to get into the tuning aspect. If I can't get the modifieds to work right, I will just throw in the stock injectors and retune for those. I will most likely be sticking w/ my VF39 for now. Maybe upgrade to a TD05H-18G, TD05H-20G, TD06-18G or TD06-20G later on...or maybe something else. We shall see. I need to get something that has quick spool to conteract the lag caused by the FMIC but also have some top end where it doesn't run out of steam. I would love a twin-scroll setup but that is $$$$ and more modifications.
NYSTI
Post by NYSTI »
NIce #'s....
Live Life To The Fullest...
gsx-lex
Post by gsx-lex »
Do you have any logs that oyu could share with us.
Have turbo, will spool.
I <3 Lesbians
gsx-lex wrote:Do you have any logs that oyu could share with us.
I just loaded the latest ECUEXPLORER software (download free here: http://www.tari.co.za/cgi-bin/yabb2/YaBB.pl) onto my laptop.
What variables do you want to look at? Here are your choices:
-Engine Speed
-Manifold Absolute Pressure
-Air/Fuel Learning #1
-Air/Fuel Correction #1
-Coolant Temperature
-Rear O2 Sensor
-Throttle Opening Angle
-Mass Air Flow
-Intake Air Temperature
-Ignition Timing
-Vehicle Speed
-Atmospheric Pressure
-Knock Correction
-Fuel Injector #1 Duty
-Throttle Sensor Voltage
-Air Flow Sensor Voltage
-Battery Voltage
-Manifold Relative Pressure
-CPC Valve Duty Ratio
-Primary Wastegate Duty Cycle
-Fuel Level Voltage
-Fuel Pump Duty
-Tumble Valve Position Sensor Left
-Air/Fuel Sensor #1 Current
-Intake OCV Current left
-Intake OCV Current right
-Intake OCV Duty Left
-Intake OCV Duty Right
-Intake VVT Advance Angle Left
-Intake VVT Advance Angle Right
-Air/Fuel Correction #3
-Air/Fuel Sensor #1
-Air/Fuel Sensor #1 Resistance
-Throttle Motor Voltage
-Throttle Motor Duty
-Main Accelerator Sensor
-Sub Accelerator Sensor
-Main Throttle Sensor
-Sub Throttle Sensor
-Memorized Cruise Speed
sirwilliam wrote: -Engine Speed
-Rear O2 Sensor
-Mass Air Flow
-Ignition Timing
-Knock Correction
That's what I would want to see. What are your A/F's at idle?
-Rear O2 Sensor
-Mass Air Flow
-Ignition Timing
-Knock Correction
I will post a log after lunch :wink:
sirwilliam wrote:I will post a log after lunch :wink:
that's disgusting
:lol2: Agreed!
You asked for it, GABE!!!!
There...let your dirty mind sink that one in!!! :lol:
do you consider it your duty to post pix like that?
Ug, I just trew up a little.
Admin warning: Keep the disgusting pictures off of the boards guys/gals... PM them to each other if you like!
Mr Kleen wrote:do you consider it your duty to post pix like that?
Doo-doo you think it is my duty?
Haha, that reminds me of the one pool scene from Caddyshack where the babyruth gets dropped in the pool. The one kid swimming comes right up to it and screams "DOODEE!". Everyone is screaming and running for their lives. Next scene you see Carl (Bill Murray) scrubbing down the pool wearing a Level 5 hazmat suit. He comes upon the so-called DOODEE, picks it up, takes his mask off, smells the so-called DOODEE, and then takes a bite out of it before continuing his work...PRICELESS!
I found a LINKY
caddyshack is a great film.
that image did make me scroll extra fast though... work and all :)
Well, I went back to Agile to get the tuned tweaked (or what I thought I would get the tune tweaked). They couldn't turn off the misfire codes/lights so I am stuck the lights and no cruise. They also keep blaming the injectors stating that they just put a large hole in the injectors and that it drips instead of the spray "Atomizing"? Hill stated that during the data logging on his laptop there were times where the 02 wouldn't register and he said that could be that the 02 is starting to go bad. Hill stated that another car they were working on ('05 STi) was having the same problems w/ the CEL lights. They replaced the 02 sensor and that fixed that. My car has 63K on the 02 sensor.
My question is this: should I get a new 02 sensor to see if it helps alleviate the problem?
In a word, yes! The O2 sensor would explain a LOT of your problems.
Although 63k is a bit early for an o2 sensor to die, it certainly wouldn't be the first time. They go for about $150 (you might be able to find cheaper if you hunt) and are not a difficult swap, if you have an o2 wrench.
I'm usually not one to "throw parts" at a problem, but that would likely remove one question mark, and it wouldn't be too much trouble to do.
cheshirecat
Unicycle
Post by cheshirecat »
I used ECUExplorer and have a buddy who is quite good at tuning with ECUFlash and datalogging ECUExplorer.....
let me know if you like his information....
Brandon
05 WRX STI
03 WRX Wagon
Racing, because all other sports require only 1 ball.
drwrx wrote:Although 63k is a bit early for an o2 sensor to die, it certainly wouldn't be the first time. They go for about $150 (you might be able to find cheaper if you hunt) and are not a difficult swap, if you have an o2 wrench.
Yeah, my buddy Frank recommended getting a slightly used one or buy some subby buxs for cheap to get a better deal on this expensive part. I am in search as we speak.
Well, I talked to Jackie at Annapolis and she gave me a heck of a deal (like usual) on a new sensor. It will arrive Monday. Who has an 02 removal/tightener tool?
sirwilliam wrote:Well, I talked to Jackie at Annapolis and she gave me a heck of a deal (like usual) on a new sensor. It will arrive Monday. Who has an 02 removal/tightener tool?
Okay, guess I will just have to find somewhere that sells these tools.
you can find them on the cheap at either sears or any auto parts store. i think mine was like $10...
complacent wrote:you can find them on the cheap at either sears or any auto parts store. i think mine was like $10...
Okay, thanks. Should I get anything special in particular. Made of gold and diamond or is the generic one good enough? Probably just grab a craftsman.
nope, just your standard O2 sensor socket. You can also use a 3/4" flare-nut wrench. I tend to bring both tools with me when I'm removing a sensor.
