2005 DCAWD AutoX class with Brian Garfield!
- ButtDyno
- Jard
- Jard
- psyber_0ptix
Only two more are needed for it to be a go, it's still quite possible!psyber_0ptix wrote:i fear thursdays class will be a bust
- ShannonO
Thoughts on whether I should my 17" OZ/Pirrelli p-zero nero set or my stock set? Pirelli's are brand new, stock tires have about 15k on them...
Is it better to learn with the good set or stock set? How much do I care about the tread wear? (I know, that's a ? for me to answer)...
Like I said...thoughts?
- ButtDyno
IMHO it depends.
I used to be in the "just run RE92s" camp until a later epiphany where I started to think that it was better to get seat time with a consistent setup. Basically I would recommend going with whatever you will actually use for autocross.
Unless you are not going to autocross any, in which case, run whatever.
john
john
- 92xaero
i may...and thats a huge may, be able to make it to the second session on june 23rd. I would need to buy a helmet, and come up with the $200 plus. Oh i forgot my car may not even be broken in by then (700 miles to go)! But the reason i bought the car is to get into auto-xing so ill try my hardest to get it to work. Do you guys think stock springs/rear sway bar are sufficient?
Whatever form your car is in will be fine for AutoX. As Brian showed us over and over again last year, it's not the car, but the driver92xaero wrote:i may...and thats a huge may, be able to make it to the second session on june 23rd. I would need to buy a helmet, and come up with the $200 plus. Oh i forgot my car may not even be broken in by then (700 miles to go)! But the reason i bought the car is to get into auto-xing so ill try my hardest to get it to work. Do you guys think stock springs/rear sway bar are sufficient?
Tom Sullivan
Damn, I'm not the only one up at this hour... but I bet you're not stuck at work like I am!Tom Sullivan wrote:im interested of course
Ok, some interesting news. I was talking with Brian about the class and he mentioned that he has a new parking lot available.
Good Things
- bigger
- will support a larger course
- should support a faster course
- no light poles
Bad Things
- it is in Sykesville, MD (west of Baltimore)
- cost would go up to about $1500, that would be another $30/person (Total of $250)
If we had the second class there, would anyone else be interested? (Colin? Zak?) Would the folks that were in for the second class be willing to pay extra?
Good Things
- bigger
- no light poles
Bad Things
Tom Sullivan
Cool. All the details are above. To get your name on the list I need a check. Some folks are using Paypal but you will need to pay the fees (+3% + $0.30). I don't cash the checks until I make the reservation so it's to your advantage to do it that way.Tom Sullivan wrote:im interested of course
Unfortunately for me, work is busybusy. I do *LOVE* the idea of a bigger courseElZorro wrote:Ok, some interesting news. I was talking with Brian about the class and he mentioned that he has a new parking lot available.
appreciate the update and the invite!
More like, woke up yesterday at 7am, did work for side clients, went to NASA at 2:30pm and didn't leave until 5:30am the following day... The the PIG F*CKER from SAIC calls me up and says, "oh, btw, since you didn't get the drug test done in time, you can't start until the 6th now" I just wanted to say "blow me" since I just stayed at work until 5:30am FOR YOUR COMPANY.ShannonO wrote:I'm confused, up at 4pm? Big deal?
