Page 5 of 6
Re: BluBallz - Sabre's 2004 STI
Posted: Mon Aug 13, 2012 1:11 pm
Oh, there will be updates very soon
Posted: Mon Aug 13, 2012 3:47 pm
I'll be sure to pull myself away from Half Life: Episode 4 to read these updates.
Posted: Thu Aug 16, 2012 8:49 am
by Cereb Daithi
I'll even put down the wrenches and stop working on my running rally car.
Posted: Thu Aug 16, 2012 1:28 pm
Cereb Daithi wrote:I'll even put down the wrenches and stop working on my running rally car.
Sweet! lol, update your thread!
Posted: Tue Sep 04, 2012 9:32 am
by psmwrx
Updates?
Posted: Tue Sep 04, 2012 11:38 am
She's up and running.... but not running well. I think that I have a cylinder misfire. Was going to try to figure out over the next week.
HUGE THANKS TO MATT (psmwrx) for letting me use his garage BTW!
Posted: Wed Sep 05, 2012 10:12 am
by psmwrx
Fuel, Air, or spark. Or all three. Is it cylinder number 4? I am sure it will be easy to figure it out logging with your laptop a few times.
You got new injectors that were flow tested, new plugs, and a snail making a lot of air. Maybe a coil pack?
Posted: Wed Sep 05, 2012 2:23 pm
Any CELs? Is it something you can "feel" like a stumble at a particular RPM, or just a general "rough" impression through the entire range?
Posted: Wed Sep 05, 2012 8:07 pm
by PGT
did you put enough boost fluid in?
Posted: Thu Sep 06, 2012 3:16 pm
psmwrx wrote:Fuel, Air, or spark. Or all three. Is it cylinder number 4? I am sure it will be easy to figure it out logging with your laptop a few times.
Not sure yet at all. You can't log individual cylinders, so I have no idea which is having issues. Spark plugs were new too. I may pull the injector connectors and then pull the plugs out to see which are getting spark as I turn it over. Could definitely be a coil pack.
drwrx wrote:Any CELs? Is it something you can "feel" like a stumble at a particular RPM, or just a general "rough" impression through the entire range?
CEL on and off, but not one that I can read. It's almost like knock, but it happens all the time. I need to remove the intercooler to check that the knock sensor isn't loose. It's a pretty rough idle, like it's misfiring.
PGT wrote:did you put enough boost fluid in?
Oh snap, I knew I forgot something!!!
Posted: Fri Sep 07, 2012 8:23 am
by psmwrx
Better you than me removing that intercooler. Those custom mounts holding that thing are a bitch.
I wouldn't be surprised though if it is something simple. You know where there is a garage if you need it.
Posted: Sat Sep 08, 2012 4:29 pm
I'm really hoping it is something simple.
Posted: Thu Oct 25, 2012 4:03 pm
HUGE thanks to Zak for the coil plug
Looks like that was the problem!
BEFORE: (notice vibration and sound)
http://www.youtube.com/watch?v=wA-Dbu4mwA8[/video]
http://www.youtube.com/watch?v=Kr7On-B5A9Y[/video]
AFTER:
http://www.youtube.com/watch?v=6WZY7-x5hHs[/video]
http://www.youtube.com/watch?v=N5mUwkYais0[/video]
She'll be at the meet on Tuesday
Posted: Thu Oct 25, 2012 4:06 pm
Rock it!
Posted: Thu Oct 25, 2012 4:17 pm
So, just bad coilpacks? Not firing on all 4
What TMIC is that?
Posted: Fri Oct 26, 2012 8:11 am
by psmwrx
Finally!
One little coil pack causing so much problems. Glad to see her on the road again.
Posted: Sun Oct 28, 2012 6:55 pm
Yep, firing on three cylinders is not good, haha.
drwrx wrote:So, just bad coilpacks? Not firing on all 4
What TMIC is that?
SSAutoChrome of IIRC
I did a couple of tuning runs today and it stayed cool to the touch!
Posted: Sun Oct 28, 2012 7:05 pm
BTW, I'll update the first post soon
lol, still taking parts off!
Posted: Wed Oct 31, 2012 1:26 pm
by iceyinferno
Good to see blue balls out and about yesterday...and it's still a quick one
Posted: Thu Nov 01, 2012 10:47 am
She's not as fast as she was, but she's still a ton of fun
Posted: Thu Nov 01, 2012 1:13 pm
My guess is you are still north of 350 whp, though not 400 whp.
That still should put you at a sub-4 sec 0-60 and a low 12 1/4 mile.
Posted: Thu Nov 01, 2012 2:24 pm
Definitely still need more tuning. I know I'm running rich and I can push the boost more
Posted: Thu Nov 01, 2012 6:13 pm
by supasixfo
awesome!
Posted: Thu Nov 01, 2012 10:05 pm
by PGT
did you pull then built motor and swap in a stock one?
Posted: Thu Nov 01, 2012 11:52 pm
Yes
