BluBallz - Sabre's 2004 STI
Re: BluBallz - Sabre's 2004 STI
Oh, there will be updates very soon
I'll be sure to pull myself away from Half Life: Episode 4 to read these updates.
I'll even put down the wrenches and stop working on my running rally car.
Sweet! lol, update your thread!Cereb Daithi wrote:I'll even put down the wrenches and stop working on my running rally car.
- psmwrx
Updates?
2004 WRX Wagon (Project)
2011 F150 Lariat (Parts hauler)
1989 Ford Bronco (The other B***h)
She's up and running.... but not running well. I think that I have a cylinder misfire. Was going to try to figure out over the next week.
HUGE THANKS TO MATT (psmwrx) for letting me use his garage BTW!
- psmwrx
Fuel, Air, or spark. Or all three. Is it cylinder number 4? I am sure it will be easy to figure it out logging with your laptop a few times.
You got new injectors that were flow tested, new plugs, and a snail making a lot of air. Maybe a coil pack?
Any CELs? Is it something you can "feel" like a stumble at a particular RPM, or just a general "rough" impression through the entire range?
- PGT
did you put enough boost fluid in?
Not sure yet at all. You can't log individual cylinders, so I have no idea which is having issues. Spark plugs were new too. I may pull the injector connectors and then pull the plugs out to see which are getting spark as I turn it over. Could definitely be a coil pack.psmwrx wrote:Fuel, Air, or spark. Or all three. Is it cylinder number 4? I am sure it will be easy to figure it out logging with your laptop a few times.
CEL on and off, but not one that I can read. It's almost like knock, but it happens all the time. I need to remove the intercooler to check that the knock sensor isn't loose. It's a pretty rough idle, like it's misfiring.drwrx wrote:Any CELs? Is it something you can "feel" like a stumble at a particular RPM, or just a general "rough" impression through the entire range?
Oh snap, I knew I forgot something!!!PGT wrote:did you put enough boost fluid in?
- psmwrx
Better you than me removing that intercooler. Those custom mounts holding that thing are a bitch.
I wouldn't be surprised though if it is something simple. You know where there is a garage if you need it.
I'm really hoping it is something simple.
HUGE thanks to Zak for the coil plug
Looks like that was the problem!
BEFORE: (notice vibration and sound)
http://www.youtube.com/watch?v=wA-Dbu4mwA8[/video]
http://www.youtube.com/watch?v=Kr7On-B5A9Y[/video]
AFTER:
http://www.youtube.com/watch?v=6WZY7-x5hHs[/video]
http://www.youtube.com/watch?v=N5mUwkYais0[/video]
She'll be at the meet on Tuesday
AFTER:
Rock it!
So, just bad coilpacks? Not firing on all 4
What TMIC is that?
What TMIC is that?
- psmwrx
Finally!
One little coil pack causing so much problems. Glad to see her on the road again.
Yep, firing on three cylinders is not good, haha.
I did a couple of tuning runs today and it stayed cool to the touch!
SSAutoChrome of IIRCdrwrx wrote:So, just bad coilpacks? Not firing on all 4
What TMIC is that?
BTW, I'll update the first post soon
lol, still taking parts off!
- iceyinferno
Good to see blue balls out and about yesterday...and it's still a quick one
04 Aspen White STi
She's not as fast as she was, but she's still a ton of fun
My guess is you are still north of 350 whp, though not 400 whp.
That still should put you at a sub-4 sec 0-60 and a low 12 1/4 mile.
Definitely still need more tuning. I know I'm running rich and I can push the boost more
- Bicycle
Alvin
Black Box rally team
Our blog: http://www.blackboxrally.com
Like us: http://www.facebook.com/blackboxrally
- PGT
did you pull then built motor and swap in a stock one?
Yes
