Getting tuned Oct. 12th at Agile Automotive
Do I need anything to put around the threads of the 02 sensor prior to installation or does it come prepped ready to install?zaxrex wrote:You can also use one of those ratcheting wrenches and thread the connector through if the space is really tight. Shouldn't be a problem for you since you have so much extra room all around compared to the GDA frame.
Why not? I think it would like it.zaxrex wrote:If you think you will be removing it, I'd put some anti-sieze on the threads, BUT MAKE SURE NOT TO GET IT IN THE SENSOR ITSELF.
