TRANS4M v2.0
Building up your car? Post up your build!
TRANS4M
Tricycle
Re: TRANS4M v2.0
Post by TRANS4M »
Re: TRANS4M v2.0
wow, that certainly is a project!
Re: TRANS4M v2.0
wowzers! that's going to be one really quiet ride. looks great!
Re: TRANS4M v2.0
Joe did something similar to his STI and I have to say it was MUCH quieter than mine.
Raven
Mr. Underpowered or something
Re: TRANS4M v2.0
Post by Raven »
WHAT IS THIS WITCHCRAFT?!?!?
Does this work to isolate road noise or just engine noise and vibrations? Cause if this will quiet down the highway ride I will do this in a heartbeat on my 2.
2013 Mazda 2
1994 Chevy S10 pickup
TRANS4M
Tricycle
Re: TRANS4M v2.0
Post by TRANS4M »
Each product has a different purpose. The CLD tiles (similar to dynamat) helps reduce resonance from vibrating panels. The MLV helps block noise. The foam serves as a gasket to separate the MLV from the panel. The car is definitely quieter on the highway.
- 2011 SWP WRX Hatch limited
Re: TRANS4M v2.0
George, keep in mind that this added 130+lbs to his car. The 2 might need a small turbo or electric assist motor to regain acceleration.
Re: TRANS4M v2.0
With sound dampening you have to "go big or go home." I tried doing a single layer of raammat and it did almost nothing for my WRX. Nice to see someone doing it the right way.
