Page 1 of 6
I think my engine is done
Posted: Tue Mar 02, 2010 12:08 pm
by goob_os101
I came to get an inspection and while in traffic I could hear a hard metal clapping sound above 2500. Shop thnks the engines bad, but not sure what part. Gotta send it in for a diag.
Re: I think my engine is done
Posted: Tue Mar 02, 2010 12:51 pm
by TRANS4M
ouch!
Posted: Tue Mar 02, 2010 1:01 pm
damn, that sucks!
*crosses fingers for good results*
Posted: Tue Mar 02, 2010 1:12 pm
Yeesh. Hope it is just something like a heat shield or crank pulley or something like that.
Posted: Tue Mar 02, 2010 1:15 pm
Agreed, could be a lot of things. I wouldn't worry.... yet. Get a shop to do a leak down / compression test and maybe even drain the oil or pull the oil pan.
Posted: Tue Mar 02, 2010 1:17 pm
by goob_os101
I always wanted and sti engine, but not so soon.
Posted: Tue Mar 02, 2010 3:16 pm
by goob_os101
I now think(hope) it is the header lose and vibrating. It only makes the sound (heavy metal and somewhat hollow) at 2500-3000rpm after that it tapers away. I put in 4th and hit 10psi and no sound. :popcorn: I am gonna go to Ft Myer's hobby shop tomorrow and throw her up on the lift and see if any piping is lose.
Posted: Tue Mar 02, 2010 7:28 pm
If you want to give it a shot, I'm pretty good at identifying header sounds. You could stop by and I could lend an ear, but with lift access so easy, it might be just as easy to go right to the source.
Posted: Tue Mar 02, 2010 10:51 pm
by goob_os101
where snd when
Posted: Wed Mar 03, 2010 9:40 am
I'm working up near Connecticut and 18th if you want during the day.
I'm at home near Edsal and Van Dorn in Alexandria in the evenings.
Heading out Fri for the weekend and have hockey Mon and Tue.
Posted: Wed Mar 03, 2010 11:19 am
by goob_os101
What time do you get home from work? I work near Kingstowne and take Van dorn home
Posted: Wed Mar 03, 2010 3:49 pm
Well hell, then you can pick me up at Van Dorn Metro. That will be a nice change from the bus. I can be at the station any time after ~ 5:15. Maybe PM me with your number and we can coordinate?
Posted: Wed Mar 03, 2010 4:19 pm
by goob_os101
see you there at 5:15
my cell: XXX-YYY-ZZZZ
Posted: Wed Mar 03, 2010 4:26 pm
goob_os101 wrote:see you there at 5:15
expect prank calls at 0100, 0200, 0315 and 0445.
:lol: :poke:
Seriously, the interwebz are a scary place. Keep personal info to PM's plz. kthxbai.
:lol:
Posted: Wed Mar 03, 2010 4:31 pm
:rolllaugh: :rolllaugh: :rolllaugh:
Posted: Wed Mar 03, 2010 7:00 pm
Well, not the exhaust manifold... :(. Large metallic clacking noise, not a simple rattle.
Only happens off load, not under acceleration.
Stuffed a 2x4 and moved the block around and the noise was still there.
Louder below the car than above, drivers' side more than pax.
Happens with trans in and out of gear, clutch in or out.
I'm stumped
Posted: Wed Mar 03, 2010 9:21 pm
I'm not sure either with that description :( Bringing it to the meet on Monday?
Posted: Thu Mar 04, 2010 9:44 am
by goob_os101
if it survives until then. :puke:
Posted: Thu Mar 04, 2010 9:49 pm
by avriette
zaxrex wrote:Well, not the exhaust manifold... :(. Large metallic clacking noise, not a simple rattle.
I'm stumped
My suggestion would be either the manifold itself being warped from spending too much time hot. Is there a way there can be a gasket that's got leakage on the turbine or the driver's side of the exhaust mani or other hot-side stuff? I don't know whether the car has an exhaust manifold gasket. Gabe said he's making full boost? And the sound is transient between 2500-3500? Might be a warped manifold or bolt. That would certainly behave like that (have a "period" when it's more clanky, and a larger period where it's happier; but it could be reversed, depending on how out-of-whack it was).
It doesn't sound like engine. Zak, it doesn't seem like a valve train clatter? It would be easier if I could hear it, but I'm going to be pretty limited on that.
Good news is, Gabe, that you probably don't have a busticated engine. Unless it's a sly and really angry gremlin (and they do exist, they're rare, but tres expensive and equally sneaky).
Posted: Thu Mar 04, 2010 11:33 pm
The real Gabe has other noise issues, this Jeremy has the engine noise...
It is def not an exhaust leak. Though with one of the six exhaust manifold studs not taking a nut, I don't see how he doesn't have a leak.
When putting the 2x4 between the driver's side valve cap and the frame rail, I could "feel" the noise through the plank of wood. Also when putting the 2x4 to my ear/jaw bone it was quite noticeable.
I'm thinking a valve lifter or shim at the worst.
Posted: Fri Mar 05, 2010 12:20 am
all I got is a clunky rear suspension. :nana:
Posted: Fri Mar 05, 2010 9:16 am
by goob_os101
could be the belt tensioner:
http://www.youtube.com/watch?v=UmZ1F8V8pc8&NR=1[/video]
or loose pulley (0:46 on):
http://www.youtube.com/watch?v=WytguVRSIMg[/video]
Posted: Fri Mar 05, 2010 11:33 am
Might be, here's to hoping.
Posted: Fri Mar 05, 2010 12:44 pm
by goob_os101
now I have my doubts...it maybe the rod bearing starving of oil at those specific rpms
Posted: Fri Mar 05, 2010 3:06 pm
I've never heard of rod bearing's being starved at specific RPMs', but I could be wrong. We'll take a listen on Monday :)
