565cc injector install
02SilverWRX
Unicycle
Post by 02SilverWRX » Sat Nov 14, 2009 8:20 am
I am finally upgrading my turbo and was wondering if anybody can point me in the right direction to a good walkthrough on how to install my 565cc deatschwerks injectors? Please do let me know asap if you know of one! I would like to get this done as soon as i can. Thanks...
2004 335 AWHP WRB WRX Stage 4
2005 525 AWHP AW STi
Re: 565cc injector install
Post by Mr Kleen » Sat Nov 14, 2009 9:11 am
is it a WRX or an STi? my WRX injector installs were a huge PITA. :x I had a couple friends helping out who had done them before.
does ScoobyMods have a thread on injector installs? they have just about everything...
Post by complacent » Sat Nov 14, 2009 5:50 pm
Definitely start at scoobymods.
if you have a 2.0l motor, you will learn about the GBODs.
Good luck, be patient. It's a PITA.
Post by Sabre » Sat Nov 14, 2009 6:12 pm
That size, he's definitely talking wrx. As stated above, check scoobymods and nasioc. We've done a couple, but (sadly) never documented it.
Post by zaxrex » Sat Nov 14, 2009 7:31 pm
One of your small coolant hoses connects to an integrated hard tube on the drivers side GBOD, so if you are not planning on re-installing the bracket, you will need to splice in a coolant hose extension.
Have you already upgraded your pump, or is that on the list as well? If you do that, don't connect the pump leads before you do the injectors, you want to have the system depressurized.
There are flat gaskets that slip around the nozzle of the injector and seat in the intake. Sometimes they stay in the manifold when you pull the old injector out. If you can, use new gaskets, and make sure you remove the old ones out of the hole. That is aluminum and can scratch easily, so avoid using screwdrivers or picks getting the gaskets out. Plastic knives/forks work well. Scratching the walls can compromise the seal and let fuel leak out.
Here is some light info from TurboXS's old stage 4 instructions.
Code: Select all
Step 5: Install the Larger Fuel Injectors
Drivers Side Injectors:
1. Remove "green" protective bracket from the fuel rail assembly by the 5 bolts. This is a "PITA" but be patient
and pull it out towards the rear of the car.
2. Remove 2, 12mm bolts between the injectors securing fuel rail to the heads and 1, 12mm bolt at the front of
the fuel rail.
3. Disconnect electrical connectors from fuel injectors
4. Pull up on fuel rail and slip out injectors one at a time. Be careful not to damage the fuel injector's rubber
gaskets.
5. Install TXS Fuel Injectors in reverse of task "4."
6. Put everything back together from "Install the Larger Fuel Injectors" in reverse order.
Passenger Side Injectors:
1. Remove the coolant assembly located next to the intake manifold.
2. Remove the various bolts securing hoses to the "green" bracket.
3. Remove "green" protective bracket from the fuel rail assembly by the 4 bolts. This is a "PITA" but be patient.
4. Remove 2, 12mm bolts between the injectors securing fuel rail to the heads, 1, 12mm bolt at the front of the
fuel rail and 2, 12mm bolts at the top of the fuel rail.
5. Disconnect electrical connectors from fuel injectors
6. Pull up on fuel rail and slip out injectors one at a time. Be careful not to damage the fuel injector's rubber
gaskets.
7. Install TXS Fuel Injectors in reverse of task "6."
8. Put everything back together from "Install the Larger Fuel Injectors" in reverse order.
Double check Installation:
1. Make sure the all electrical connectors are installed to the fuel injectors.
2. Make sure electrical connectors are installed to the Tumble Generator Valves if removed during installation.
3. Make sure the fuel pressure regulator line is attached and secured. If installed improperly, serious engine
damage can occur as fuel pressure will not increase with boost.
4. Plug the green connector back in from "Depressurize the fuel system."
Email me if you want the whole PDF.
02SilverWRX
Unicycle
Post by 02SilverWRX » Thu Nov 19, 2009 9:51 pm
Okay, I installed the 255 fuel pump from walbro, drove the car with no problems.
Yesterday i installed the injectors but didnt run the car.
Today i installed my VF39 and when i went to turn the car on after everything was completed it wont crank, the car in acc mode allows everything to work (radio, gauges, accessport, headlights, etc...) but it will not crank.
Here are the things i have tried:
Reset the ECU
Used different cobb maps
jumped the car
checked all grounds i am aware of
checked all sensors i can see
There are no leaks-However, when i first tried there was a leak from one of the injectors and so i took off the fuel rail and reinstalled it and there isnt a leak any more. Somebody please help me out :( :(
02SilverWRX
Unicycle
Post by 02SilverWRX » Fri Nov 20, 2009 12:37 pm
:poke: :poke:
Post by complacent » Fri Nov 20, 2009 12:48 pm
after you flashed your maps, did you take the car out of diagnostic mode? I'm not sure what it is on an 02, but on my 04 it was a pigtail connector up by the OBDII port.
Post by zaxrex » Fri Nov 20, 2009 1:49 pm
Depending on how you depressurized the fuel system, you may have disconnected the crank angle sensor/ fuel system relay/ MAF sensor.
I had the same thing happen to me. I forgot to plug the MAF sensor back in after upgrading the filter...
Post by Sabre » Fri Nov 20, 2009 2:19 pm
As in the engine doesn't turn at all?
02SilverWRX
Unicycle
Post by 02SilverWRX » Sat Nov 21, 2009 3:09 am
No when i put the key in the engine wont turn at all. It doesnt even try, i can spin the crank freely though with a 22mm ratchet & socket... We depressurized it by removing one of the fuel lines near the filter and then reinstalling it.
Post by Mr Kleen » Sat Nov 21, 2009 8:36 am
i had problems with the crank angle sensor IIRC, but even then the car would start it just threw a CELL. it may be time to call in the Pro's... :|
Post by Sabre » Sat Nov 21, 2009 2:21 pm
Something is up with the starter I would guess then. If it's not turning over at all, then the starter isn't getting juice. Check the voltage at the starter when you try to crank it.
Post by zaxrex » Sun Nov 22, 2009 12:43 am
I would not be so quick to jump on the starter. There are many sensors that need to give input before the ECU will let the solenoid kick over on the starter circuit. One of them may have been disconnected or knocked loose.
It could also be a current issue. Are the battery cables secured to the battery? Might be touching just enough to power your ACC, but not enough to give the juice to start.
Only thoughts I have.
Post by Sabre » Sun Nov 22, 2009 11:03 am
I figured it would be good to go from there back... If he's getting at least some voltage, everything is good and he's just not getting enough juice. If he isn't, he works backward :)
02SilverWRX
Unicycle
Post by 02SilverWRX » Sun Nov 22, 2009 12:29 pm
I didnt have a chance in the past couple days to work on it but i am installing a new battery now. I have a mechanic friend from subaru who is going to come over and jump the starter to see if that is the problem.
