So my front passenger window has been making a horrendous squealing noise every now and then as it's being lowered. I finally got fed up and did some searching for a solution. I should have known it'd be an easy fix.
Got some silicone spray lubricant (this brand). Cleaned the window first, lowered it, sprayed the lubricant into the vertical piece of rubber on the front of the door, and tested. No squealing!
So if anyone else is having this problem - now you know what to do. That's my PSA for the week.
Window Squeak Solved!
Re: Window Squeak Solved!
Good to know.
I just book-marked Jig-a-loo.
Mine too has been making this squeak... going to do this when I get BluBallz back!
one of the rear windows has been doing this every so often for a few months. time to visit the hardware store. thanks for the tip!
