Matt! Turbo inlet pipe questions!!!!
DamSedan
Post by DamSedan »
Ordered a gp moto inlet pipe the other day and should have it by the end of the week. What problems did you have with yours? I remember you saying something about one of the connector holes being too large or something like that. Was this one that was made for a WRX and not the sti? Is there a difference or was there back when you got yours?
For those that do not know, the DRNWAGN is at Hillmoth waiting for Andrew to come back from vacation. I have a cracked oil supply line to my turbo. This is in the lower portion and will require removing the intake manifold, tmic, coolant res, inlet pipe, maybe a fuel line and finally the oil line! The part is only $90 but the labor is going to be about $600! None the less, since the intake manifold is coming out I figured I would get a new inlet pipe and throw it in there just for GP (no punn intended). Should have the car back on the road by Tuesday or so.
I will always be the DRNWAGN!
Dude, that sucks! Sorry to hear about the problems. Any idea what caused it?
Couldn't be with a better guy though, I have heard nothing bu good things about Andrew.
DamSedan
Post by DamSedan »
I never actually tuched the lower portion of this line. However, you have to connect the upper portion to the turbo. All I can think of is that when I was connecting it I may have bent it or something causing a small crack. Over time it has grown to the point that it is now dripping oil all over the place! I got lucky I caught it in time or else things could have been much worse.
